Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 02, 2007
Old     (knarbar)      Join Date: Nov 2006       05-17-2007, 3:31 PM Reply
Well i posted a few tricks i really want to dial in the summer and noone posted so maybe ill get beter results here. Ive been trying the moby dick for awhile. Im finally catching the handle as I rotate over but I stall as i come around for the bs3 either catching a mean hs edge or I end up doing an off axis bs360. Any help handle position cut anything
Old     (riz)      Join Date: Apr 2006       05-17-2007, 3:49 PM Reply
To rotate the first backside 180 properly try holding the handle behind you with both hands a little longer until you come around. Then you'll be upright and in position to pull the handle across your body to finish off the last 180. In short: hold the handlepass longer and then pull it across your body at the end.
Old     (knarbar)      Join Date: Nov 2006       05-17-2007, 4:44 PM Reply
thx man that makes sense cause as soon as i release from the wake i try to pass the handle as fast as poss.
