Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 13, 2007
Old    umdank            02-28-2007, 8:19 AM Reply
Do fatsacs or adding weight mess up your boat? It can't be good right?
Old     (thane_dogg)      Join Date: Jun 2002       02-28-2007, 9:53 AM Reply
short answer, yes.
Old     (malibuboarder75)      Join Date: Jan 2004       02-28-2007, 10:10 AM Reply
How does it mess up your boat?
Well it puts more stress on the engine, hull, floor, and stringers. If the weight is evenly distributed, it isn't that bad. But over time it will eventually weaken the boat.
Old     (wakebrdr38)      Join Date: Sep 2006       02-28-2007, 10:11 AM Reply
i dont think so, just dont overload it. you gotta be smart about it. never store them filled on the trailer. that for sure would be a nightmare!
Old     (dtb)      Join Date: May 2002       02-28-2007, 10:23 AM Reply
I have kept mine filled on the lift for days at a time before. Are you telling me the boat will eventually fall apart?
Old     (guido)      Join Date: Jul 2002       02-28-2007, 10:28 AM Reply
No way..... I've weighted every boat I've owned and they're spotless when I'm done with them. You can abuse a boat whether weighted or not. Running around with 1200lbs of sacks all the time is just the same as if you had 10 people on the boat.
Old     (malibuboarder75)      Join Date: Jan 2004       02-28-2007, 11:16 AM Reply
Well what is your definition of messing up your boat? You cannot tell me that adding 1500lbs of weight everytime you take the boat out wont wear down the boat over time. Sure it is the same as having 8 people in the boat, but 8 people will mess up your boat even more.
So the answer to 'will it mess up my boat?' is yes. But it is probably negligible wear. Now adding 3000-4000lbs plus people like some will definately hurt the transmission, engine, and hull over time.
Old     (longhornfan)      Join Date: Oct 2005       02-28-2007, 11:48 AM Reply
I wonder if Gerry Nunn has a hard time selling his boat after he's ran it a year with all the weight he packs.
Old     (rmcronin)      Join Date: Aug 2002       02-28-2007, 11:59 AM Reply
My sacs caved in the floor behind the engine box in my old Prostar. Newer floors are reinforced to handle sacs on them.
I think you should change your oil more than every 50 hours if you are running with a lot of weight. I change mine each 30h and it is already pretty black by that time. Compare the color of your boat's oil after 30+ hours running with 1500lbs+ to your car's after 3000mi.
What is most important is that you maintain your boat regularly and use it a lot. A boat with 100+hours a season that gets regular oil and impeller changes will usually have fewer problems than a boat that is rarely used. Emphasis on "usually"
Old     (jhertz27)      Join Date: Jul 2005       02-28-2007, 12:18 PM Reply
Yes, adding weight can “mess” up your boat in the long run, along with a many other things. Is it worth it? Heck yes it is! Just be sure to do the regular maintenance work and empty your ballast after you ride.
Old     (socalwakepunk)      Join Date: Dec 2002       02-28-2007, 12:26 PM Reply
Adding weight is less damaging to the boat than neglecting maintenance or abusive driving....
Old     (ironcross25)      Join Date: Jul 2006       02-28-2007, 12:48 PM Reply
So If I add 300 lbs of sand bags in my rear ski locker and 200 lbs under my bow and leave them in there will I be ok?
Old    walt            02-28-2007, 12:54 PM Reply
It's probably not as bad as the people that run around the lake wide open throttle all day.
Old     (wakesetter101)      Join Date: Oct 2005       02-28-2007, 1:36 PM Reply
Lets just say that it isnt helping your boat, or my boat. .
Old     (bennygoodx)      Join Date: Aug 2006       02-28-2007, 1:44 PM Reply
MOre often than not, I"ve got 3000lbs plus of weight in mine. Doesn't seem to do a darn thing to the integrity of the boat.
Even if it does mess it up, who cares??? You can't have fun without the weight.
