Old     (liquid_force24)      Join Date: Apr 2006       06-17-2010, 8:18 PM Reply
http://www.youtube.com/watch?v=_QjhAZ_P6N8
Old     (cheesydog)      Join Date: Mar 2009       06-17-2010, 8:23 PM Reply
nice bro!
Old     (drewproses)      Join Date: Oct 2008       06-17-2010, 8:39 PM Reply
Very nice! I never knew it was called a C7. Im having a really hard time learning the toeside flick... any advice?
Old     (hyperlite)      Join Date: May 2009       06-18-2010, 4:19 AM Reply
me too
Old     (liquid_force24)      Join Date: Apr 2006       06-18-2010, 4:42 AM Reply
the main things with toeside tricks is body position! keep that handle as close to your hip as you can, chest up, shoulders back and dont break at the waist or knees! try to keep your body as straight as you can! do all this and it'll ensure a nice load on the line and plenty of pop!
toeside scoop is pretty much the same thing as heelside... you want to scoop away from the cable with your board (the easiest way i found to learn this was to pull the handle across you body and hold it at your back hip and then do a double cut and try and scoop on the second cut! this helps learn the scoop but keeps you on axis) with the scoop you want to make sure you scoop your back foot heaps... make sure you scoop your back foot out to the side so you dont go dental chair and try and keep the handle low once you have scooped!
if you can decipher that rambling i hope it helps
