Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 14, 2005
Old     (kystyle)      Join Date: Aug 2005       09-12-2005, 3:45 PM Reply
I've got a 95 Sport Nautique with a Pro Boss engine, and I'm having trouble changing the transmission fluid. The only way I know of draining the fluid is to siphon it out, but I can't seem to get any suction. If anybody's got any advice or if anybody knows anybody that has a Nautique that is about as old as mine please let me know.
Thanks
Old     (grant_west)      Join Date: Jun 2005       09-12-2005, 8:18 PM Reply
Mike: Make sure you have a good fluid pump, I have the Jabsco hand pump and it works great for changing the fluid in my 2002 Air nautique. 5 min and your done. I use the same pump to change the Motor oil
Old     (jarrod)      Join Date: May 2003       09-12-2005, 9:00 PM Reply
buy a fluid pump at a marine store. Cheap and quick.
Old     (azwakekid)      Join Date: Apr 2005       09-12-2005, 9:44 PM Reply
is your fliud really that bad? my the boat shop i work at we hardly see had atf in trannys i think we change it like every 250 hours i think. just cause the fluid never goes bad, thoes trannys are bullet proof pretty much
Old    ryan_bailey            09-12-2005, 10:33 PM Reply
on my PCM Power Shift tranny there is a drain plug. pumping it out might not be really that good since you wouldn't get all the crap in the bottom of the case. Look for a drain plug, mine was on the bottom and only took one of this special alan keys.
Old     (superairdawg)      Join Date: May 2003       09-13-2005, 4:53 AM Reply
Get your hands on a drill pump and changing tranny fluid AND crankcase oil will be a snap!
Jabsco makes a good one you can get at a number of places. Check it out.
http://www.jamestowndistributors.com/product;part;11281;process;search;ID;,Engine.Room,Fuel.Li ne.Items,Jabsco.Drill.Pump
Old     (kystyle)      Join Date: Aug 2005       09-13-2005, 5:04 AM Reply
Thanks for the advice, the fluid still looks good, I'm just paranoid about the life of my engine because I run it with so much weight in the boat.
