Old     (prior40)      Join Date: Feb 2004       03-16-2004, 8:38 AM Reply
i can ollie, but not very high. any recommendations on how to get higher?
Old     (tiger20)      Join Date: Sep 2001       03-16-2004, 3:46 PM Reply
Getting high? - try holding it in longer or coughing....
(Message edited by tiger20 on March 16, 2004)
Old    missjade            04-06-2004, 12:15 PM Reply
I have the same problem as Tim. I can't seem to get any pop on my skate for an ollie. How is it different from a wakeboard ollie? I can barely even get the board out of the water.
Old    wakeskate247            04-06-2004, 5:58 PM Reply
ok with a wakeskate you cant lift the nose of the board up with your front foot, so the height of the ollie comes from how hard you slam the tail into the water. Try slowing your speed down to make the water softer under you, to allow for more movement into the water. Also later on once you get more comfortable on your skate try pulling the handle in to your leading hip while performing the ollie this will get you a little more height.
