Old     (brucemac)      Join Date: Dec 2005       04-22-2008, 8:27 AM Reply
ordering a new mainline and handle. was going to order either white or black a-line. prefer black, unless it's impossible to see. can you see it okay in the water or should i just get white? also is that 2008 accurate murray ars handle decent? was going to pick that up too. thanks.
(Message edited by brucemac on April 22, 2008)
Old     (hal2814)      Join Date: Feb 2006       04-22-2008, 8:30 AM Reply
I've got the white and I have a hard time seeing it in the water sometimes. That sucker sinks pretty fast. I'd just get the color you like and not worry about it. I use a cheap handle so I can't help you there.
Old     (clubmyke)      Join Date: Aug 2004       04-22-2008, 8:34 AM Reply
cant see it
Old     (chadgreg)      Join Date: Feb 2008       04-22-2008, 8:41 AM Reply
Can't see black!
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-22-2008, 8:52 AM Reply
not underwater black, for sure.
get a white handle (thats floats0 and you'd be fine. another reason i hate carbons.
Old     (cmcathy1)      Join Date: Dec 2007       04-22-2008, 8:59 AM Reply
I have the A line in black and it doesn't matter what color you get because unless your moving it is going to be underwater
Old     (liquidmx)      Join Date: Jun 2005       04-22-2008, 9:08 AM Reply
I have ridden with a black, white, red and pink coated lines. Black is BY FAR the hardest to see (if you see it at all). White and pink are the easiest to see, then red. Given a choice I would never get a black coated line.
Old     (brucemac)      Join Date: Dec 2005       04-22-2008, 9:09 AM Reply
should i be looking at another rope then?
don't all the non-stretched coated lines sink?
does that accurate murray ars handle float?
Old     (cavlxenvy)      Join Date: Aug 2007       04-22-2008, 9:21 AM Reply
I have a black rope and black handle. I have no problems seeing it.
Old     (westsidarider)      Join Date: Feb 2003       04-22-2008, 3:59 PM Reply
-most non-stretch ropes do sink
-yes the murray handle floats
get the black. it looks dope and it is more resistant to stains and you are less likely to see the cracks in the coating after tons of use.
