first off you have to realise that the board doesn't do all the work... to get big air you need to have a good hard wake well shaped and have proper edging technique... if you already have this down, now you can start to look for boards with agressive three stage rocker board that are wide... those will give you more of an upward kind of lift and a lot of snap off the wake... If you want to go way out in the flats, you need to use a wide approach, carry more speed and look for long and wide board with moderate continuous rocker...
