Old     (hawk22)      Join Date: Jul 2006       09-11-2007, 11:55 AM Reply
so my boat has been running great since I figured out the alternator issue. Checked oil yesterday just to see and couldn't get a reading so I added 3 quarts. Checked again today to see if had burned it all up after yesterday and the whole dipstick is covered in a grayish sludge. Does that mean my engine is cracked? I suspected at the beginning of the season because the freeze plugs were popped, but I had it checked and they couldn't detect any leaks and the oil looked fine after a few test runs.???
Old     (nasty530)      Join Date: Aug 2007       09-11-2007, 11:59 AM Reply
Light gray oil means that water has mixed with the oil. It is possible it is a very small leak, thus the delayed detection
Old     (peter_c)      Join Date: Sep 2001       09-11-2007, 1:17 PM Reply
The first thing you need to do is determine where the leak is. A little sludge on the stick is not a concern, but if the oil is milky then there is a problem. It will take a pressure test to determine if and hopefully where the leak is. Could just be an intake gasket leak, which is no biggie.
Edit: pull the drain plug and see if water comes out.
(Message edited by peter_c on September 11, 2007)
Old     (hawk22)      Join Date: Jul 2006       09-11-2007, 2:30 PM Reply
sorry to be ignorant, but what pressure am I testing? oil? leak down? compression?
Old     (peter_c)      Join Date: Sep 2001       09-11-2007, 2:41 PM Reply
Someone will need to close off the engine cooling system and put 14 psi of water pressure into the system closed up, then watch for a drop in pressure and for water leaking either into the engine or externally.
