Yeah, the 24Ve is not the best platform I've been behind. It'll be hard to get the face to clean up, you'll probably wind up with a secondary lip much like a poorly weighted Enzo. First, get rid of the bow weight. The Tige's all weigh in at 4K + without ballast so you don't need extra weight up front. The bow weight just mucks up the wake. Under the port side bench seat, try and fill that up with a long tube sac or a few side sac's. The port rear compartment if you don't have a rectangular sac to fill it in, try two fat sac's one on top of the other. On your taps, start at 4'ish and play with that as you burn gas through the day. Set your speed at around 10.5 on PP, if the face is all white washy, try increasing the speed at one bump on PP and let the boat settle in before bumping the speed up more. If that doesn't work, run the boat speed up past 10.5 - jam the throttle to get the boat up to say 13, then let it settle back down. Give that a shot and let us know how it worked out.
