Kalen, If your switch is anything like mine, there is a small round button that you can push, but it won't stay in. However, there is a lever like switch that you actually rotate and that resets the switch. The small round button actually releases the lever switch, disengaging the switch. When you rotate the lever, the button actually goes out. You can tell because without the lever locked in, the small button pushes with no resistance. When the lever is rotated and locked in, the small button is solidly out and if you push it then, the lever releases and rotates. It took me a while to figure out what to do with the lever/button. In addition, it is really hard to even see the switch so you are doing it mostly by feel. Hope this helps.
