I'm converting from hard plastic tanks to fat sacs to get more weight and I'm wondering which way to install the new bags. I haven't purchased them yet but from the pictures it looks like they all have two fill openings on the top. Is this the way that you install them or do you face the openings down. It seems like with the openings up you would have a hard time draining them but with them down the air wouldn't bleed out. Also, with two openings how does the overflow work. Does it come out the drain hole and flow through the pump?
