Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old     (alcarlaw1)      Join Date: Jun 2007       07-03-2007, 6:44 AM Reply
Hi, does anybody know what amperage causes the circuit breakers on a Nautique to switch? I am planning on running a ballast puppy from one breaker and if I can get away with not using relays then it makes my life a little easier. Cheers,
Old     (sinkoumn)      Join Date: Jan 2007       07-03-2007, 7:08 AM Reply
Which breaker are you planning to use? What model of nautique? What engine??
I think the breakers on my super sport's GT-40 are 60, 15, and 12.5amps.
You're better off just buying a new breaker and wiring the pumps through that IMO.
(Message edited by sinkoumn on July 03, 2007)
Old     (peter_c)      Join Date: Sep 2001       07-03-2007, 9:16 AM Reply
Use relays and fuses. Do not grab power from the dash area, as it is not set up to handle any extra load (Gauges start doing funny things). Instead get power directly from the battery or engine.
The more amperage and voltage available to the pumps the faster it will drain and fill.
