07-09-2007, 9:42 AM
I am looking at getting a boat and I really like the vtx. I have ridden in the vlx but have never gotten a chance to demo the vtx. I was wondering if anyone could give me some insights to the boat (wake, handling, pros/cons) before I take the time to possibly demo one.
07-09-2007, 10:04 AM
Bryan, We had an opportunity to board behind Corrie Dyer's VTX it was great. We had a boat load of people, MLS plus power wedge at half (Power wedge is a must) the wake was great.
07-09-2007, 2:43 PM
I demo'd it. It's a nice boat, good wake, good surf wake too if you add some weight. Kinda expensive for a 20ft boat.
07-09-2007, 4:22 PM
I own it and I love it. The wake is great and when you are just messin around the boat handles like a sportscar. I have the 340, its worth the money. As far as cons go, the only ones I can think of are aesthetic. I don;t really like the chrome window bars, but they dont bother me that much. Sometimes I think that the bow looks a little too small. Other than that, its an awesome boat. I surf and ride behind it and I have no complaints. I wish I had gotten the bow ballast, but I bought it off the lot.
07-09-2007, 7:04 PM
own one also. Love the wake and handling! Surfed fore almost a mile this weekend with 3 people in the boat with the center and 1 side balist full with the wedge down. Wish I would have gotten the front balist also as the boat rides bow high when weighted.
07-10-2007, 5:11 AM
07-10-2007, 8:28 AM
I got one and i love it. The boat has a ton of space for a 20 footer. with it being a smaller boat it doesn't take much to sink which helps with gas. with stock mls the wake is really pretty nice.
07-10-2007, 12:41 PM
I sold my 2007 Wakesetter VLX, and have been using a 2007 Wakesetter VTX until my 2008 VLX comes in. It has all four tanks like my VLX, but is on the diamond hull instead of the wake hull. I was really surprised, but the wake is good with some weight. I'd like to see what a VTX with the wake hull is like. Wade- dude put your mirror on the driver's window, not the center window! I think you will find that it works better!
07-10-2007, 12:47 PM
The center window is tapped and threaded for that mirror, should he drill and tap the drivers side, then have it in his way all the time?
07-10-2007, 12:55 PM
Mine just clamps onto the window frame. The mirrors for the new windshield are different than the traditional. (Message edited by Trentster on July 10, 2007)
07-10-2007, 12:56 PM
oops double post (Message edited by Trentster on July 10, 2007)
07-10-2007, 1:03 PM
Oops my bad, thought it was like the 06's where the mirror screwed into the frame. New windshield, do you mean the vented one?
07-10-2007, 8:47 PM
I believe it was Power Boat Mag boat of the year. My boss just bought one with the stroker motor in it. They got towed in the first day they put in the water. Hose blew of the muffler...
07-11-2007, 5:37 AM
Trent, I will try that today thanks.
07-11-2007, 7:41 AM
07-11-2007, 9:18 AM
Thanks for all the input everyone. The optional bow ballast and power wedge seem like a must.
07-11-2007, 10:29 AM
Bow ballast definitely is but so is a willingness to add your own. I'm of the opinion that the stock ballast is not sufficient - even with the bow ballast option. The manual wedge is fine. Once it is weighted heavily you likely won't want to even use it.
07-11-2007, 10:58 AM
Just picked up my VTX saturday and the Boat rides great. With three people and Standard Ballast with wedge the wake is Great. I am very happy with mine.
07-11-2007, 1:55 PM
did someone slalom behind that boat, especialy with the diamond hull?
07-12-2007, 12:41 AM
Yes, it's pretty flat! We even ran one in the course and my buddy Troy started at 22 and got into 35 off behind it at 34 mph. He said that the only thing that was an issue was the slight bump at the longer lengths. From a driver's standpoint it is harder to stay right in the middle of the boat guides because the rope is attached towards the back instead of in the middle of the boat. My only suggestion is to adjust the tunable rudder so that it wants to pull to the right like a normal ski boat. It's easy- just loosen the two allen screws on the rudder and move it a little each time. We just left the trailer in the water, adjusted, ran the boat for a minute, pulled it back out, adjusted, and so on. We got it perfect the third time. From the factory its adjusted so you can let go of the wheel at wakeboard speeds and the boat goes straight instead of wandering to the right.
07-30-2007, 10:08 AM
Trent - quick question - why would you want it to wander to the right? Mine does and I want it to go straight when I let go of the wheel... ??
07-30-2007, 10:16 AM
Its a great boat minus the silly vented windshield -- a beauty with a big pimple on it's forehead.
07-30-2007, 10:22 AM
If you want to drive straight through a slalom course it really helps to have torque from the thrust of the prop on the steering wheel. This was always present until Malibu started using the adjustable rudder in 2006. From the factory they adjust the rudder so that it actually makes the boat go straight ahead when you let go of the wheel. The trade-off in the 32-36 mph range is that the steering is not "crisp." It actually feels really loose and the boat wanders all over when going through the boat guides in the slalom course. That's the only reason you would want to adjust the rudder so that it is back to neutral and there is torque steer to the right. You probably never noticed it in the pre-2006 boats, but trust me it was there. If you let go of the wheel the boat would go to the right.
07-30-2007, 10:23 AM
07-30-2007, 10:28 AM
Trent - thanks for the info. I asked because I have a 2007 vride and the did not adjust it. It pulls to the right. I have been trying to get it to run straight, so I was curious on why you would want it to turn. Makes sense. Take care.
