Are you riding more boat or cable? You have a lot of press and grind options, so I'm assuming cable. If it is primarily for boat, I would eliminate all of your choices except for the Vahalla, Axis, and possibly the X-Faction if you may do both. Are you looking at similar prices for all of these? I have a Local and I think it is an under-rated board, but primarily for cable. The rest of your choices with a grind base will just be heavier than the standard bases.
