Old     (typhoon)      Join Date: Jul 2001       03-05-2003, 11:28 AM Reply
They do other sacs also but the custom sac he made for me is awesome. He did a 9x28x80 sac for under my floor. Very reasonably priced also. I had him put on 3 of the 1" nozzles. The other very nice thing is that the nozzles are made of abs or pvc so you plumb right onto them instead of the flimsy nozzles on sacs like my old fly high. The material is a very tough, zodiac type of material. Too cool.
Old     (typhoon)      Join Date: Jul 2001       03-05-2003, 11:30 AM Reply
oh yeah-about 700 lbs.
Old    chris_hargis            03-05-2003, 11:51 AM Reply
Price?
Old     (typhoon)      Join Date: Jul 2001       03-05-2003, 11:52 AM Reply
if I remeber correctly it was 132.00 delivered.
Old     (typhoon)      Join Date: Jul 2001       03-05-2003, 11:53 AM Reply
you can email pete law and get any quotes and sizes at this address:
ete@letsgoride.com">pete@letsgoride.com
Old     (greatdane)      Join Date: Feb 2001       03-05-2003, 11:58 AM Reply
Those are awesome!
Old    lunker            03-05-2003, 3:42 PM Reply
I'd love to see it in place.
Old     (paulsmith)      Join Date: Mar 2002       03-05-2003, 6:27 PM Reply
That looks killer. I want one for the trunk in my LXi! I intend to hook it up to a self-priming reversable pump and a switch for some killer auto-ballast!
Old     (greatdane)      Join Date: Feb 2001       03-05-2003, 6:37 PM Reply
Time for me to replace the factory sack in my MLS (Malibu Leak System). It will be so great to not have 3" of water in the bottom of my boat after every day on the water!
Old     (liveoz)      Join Date: May 2002       03-05-2003, 9:30 PM Reply
only three inches?
I usually grab my manual rule 1100 a couple of times a day and empty the locker.
Old     (barry)      Join Date: Apr 2002       03-05-2003, 10:20 PM Reply
Had mine in for almost a month now, I love it..
Pete took care of everything quickly from start to finish.
Great sac.
B-
Old    steveaz            03-05-2003, 11:26 PM Reply
Where's the 3rd one? Underside? One for fill, one drain, one for vent?
Hey Dane, so you fix your leak problem, then what are you going to do? You'll be running a couple hundred pounds lighter. Careful what you ask for.
Old     (greatdane)      Join Date: Feb 2001       03-05-2003, 11:41 PM Reply
Good point steve. But, I can get a bigger sack for the ski locker. And, I got 390 lbs of lead at the boat show!
Old     (typhoon)      Join Date: Jul 2001       03-06-2003, 6:57 AM Reply
I actually use the sac upside down. The nozzles you see are on the bottom. One is capped and the other hole on the other side and top of the fill hole I use for the vent line. He will put them anywhere you want them though. I went with this in case I ever want to change my ballast system and I can also use my atwood 750 on the top capped line if my pump ever fails. I did use flow rite quick release in case I ever want to pull the sac out.
Old     (typhoon)      Join Date: Jul 2001       03-06-2003, 6:58 AM Reply
Paul,
when you get ready I will hook you up on all of the ballast supplies for a system if you need anything.
Old     (rocketman)      Join Date: Feb 2003       03-06-2003, 11:27 AM Reply
Ty,
Be careful you don't overfill since you're putting that in the ski locker area. I did a search on this site over the weekend, and I ran across a thread where some guy's vent got plugged, and the pumps pumped so much water in the ballast that it damaged the boat. I would hate to see you damage your boat. I know it got me to reconsider my original ideas for concealed ballast.
Old     (typhoon)      Join Date: Jul 2001       03-06-2003, 11:29 AM Reply
I agree. when I fill I do watch the sac also through my opening.
Old     (paulsmith)      Join Date: Mar 2002       03-09-2003, 6:34 PM Reply
Ty, I'd appreciate that. I'm very stoked to get the back bag automated.
Old     (typhoon)      Join Date: Jul 2001       03-10-2003, 6:35 AM Reply
Just let me know when and I will supply you all the info. I found everything and very inexpensive. drop me an email when you want.
