I would think a Y-cable would work if you were not trying to control the head unit with the two on the y-cable at the same time. The XMD only has two remote plugs sticking out of the back of the unit. What you should do is go get a y-cable and hook up the two you have currently to the same plug and see if that works, if so, go get another remote. The only thing I think that might be a problem is pulling too much power from the head unit to run the remotes. I ran into a problem with that unit when I put two amp on the same amp on wire. The unit would shut itself down after a few seconds. It took me two hours to install a sub and amp, and another two hours to troubleshoot the thing. IMO, that head unit is way too complicated for what is needed in a boat. (Message edited by byrd on March 21, 2006)
