Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 09, 2007
Old     (p_e_ski)      Join Date: Jul 2004       01-09-2007, 7:05 PM Reply
Currently have 1 pair of 4 ohm tower speakers rated to 125watts RMS, with amp that runs them at 120 RMS x2. Want to add 2 more speakers but cannot add any more wiring through the tower so I am going to run them in the parallel mode from a more powerful 2 channel amp. Since I am doubling the speaker power to 250 per channel, is it safe to assume that I should select an amp that pushes 250 RMS x 2 also. Or is there some super secret calculation that I need to know.
Old     (pickle311)      Join Date: Oct 2005       01-09-2007, 7:23 PM Reply
as long as you run the amp in stereo you will be ok, that will be a 2 ohm load per channel and most amps will run that with no problem
Old     (mikeski)      Join Date: Aug 2003       01-10-2007, 5:15 PM Reply
As long as it's a two channel amp you should be fine. If you want to use a bridged four channel amp they will need to be wired in series.
