RK,
This is how I wired my three simer pumps. I cut the aligator clips of the ends of the wires that the pumps come with. The lines have a inline 20amp fuse. I bought a dual bus bar which I am going to feed with a 8 ga wire from the battery. From there I am running a 10 ga wire to each of the switches. The 10ga goes to the center terminals on the switches and the pump wires go to the top terminals. Then run a jumper wire and cross them to the bottom terminals so that the pump will reverse. Should work fine. Let me know if you have any questions.
