Here is a list(always adding to it), that i used, it is from WW, modified a little bit. (and what I did for each, if anything. Here is also a link to a pdf for a manual, some might help even though its a different boat. In the back they have maintenance. Engine oil & filter, changed both, quicksilver 25w-40 from bass pro shops, and kn filter. Fuel filter, done from skidim. Remove, clean, & reinstall spark arrester Pull, clean, & regap spark plugs, new put in, NGX from skidim. -I replace them every 2-3 years Drain & refill tranny, done from napa, dexron 3. Impellor (replace), done from skidim. Squeeze all hoses, checking for soft spots (replace as needed), checked, good. Check all belts for tension & wear (replace as needed) Check battery, done bi monthly. Lube steering and throttle cables, Grease rudder shaft, Grease trailer hubs, done monthly.
