Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (cccbuilders)      Join Date: Jun 2007       07-26-2008, 3:17 PM Reply
Does anyone have a separate volume control, for the tower speakers and the int boat speakers?
Old     (oaf)      Join Date: Jul 2002       07-26-2008, 3:35 PM Reply
Yes. I run 2 pac-2 controlers that control the gain on each amp. easy install doesn't cost much to do
Old     (uofamox)      Join Date: Feb 2007       07-26-2008, 4:29 PM Reply
wetsounds ws 420 equalizer for me. Couldnt be happier with it.
Old     (dohboy)      Join Date: Aug 2007       07-26-2008, 4:32 PM Reply
I seperate my speakers with an EQ as well. An EQ is almost manditory with all the gain controls. Kill two birds with one stone.
Old     (04outback)      Join Date: Jul 2007       07-26-2008, 7:10 PM Reply
Clarion EQS746 is a cheaper option than the WS-420 if you are looking for that.. Search ebay and google and you can find some great deals.
I have one and love it. I run my sub through it, my tower speaker amp and cockpit speaker amp. you can fade between tower and cockpit to have more on tower/less on cock pit and control sub separately.. Plus it is an EQ..
Best,
B
Old     (chpthril)      Join Date: Oct 2007       07-26-2008, 7:44 PM Reply
Tower amp on the "Rear" head unit RCA's and the cabin amp on the "Front" head unit RCA's and just use the fade knob.
Doesn't cost me a dime to set it up this way.
Old     (kitewake)      Join Date: Jul 2007       07-27-2008, 1:36 AM Reply
Pioneer Premier DEH-P800PRS HU
Zapco SP4-SL
Zapco 360.4
Zapco 350.2
Zapco 500.1
(2)Polk Momo 6.5
(2)Polk Mome 6x9
(2) Wetsounds Pro80s
(1) JL 10W6
A full fange unfiltered signal feeds a the SP4-SL from the HU. The SP4 takes that signal, and provides 3 outputs, Front, Rear and Sub. It has a fader and sub control prior to the volume control on the SP4. Works awesome.
I send the SP4 'Rear' output to a 360.4 driving the (4) Polk Momos for the cabin. I send the SP4 'Front' output to the 350.2 driving the wetsounds on the tower. I send the 'Sub' output the 500.1 driving a JL10W6.
I can balance the cabin levels by using balance on the HU...and the two gain adjustments on the 360.4. By changing the fader adjustment on the SP4, I can crank the tower without blasting out the cabin. Sub adjustment scales with volume.
It the SP4 is the perfect processor for a boat application.
(Message edited by kitewake on July 27, 2008)
Old     (65sanford)      Join Date: Feb 2007       07-27-2008, 12:39 PM Reply
I use PAC LC-1 level controls fro each pair of speakers--work great and are cheap and easy to install
Old     (05mobiuslsv)      Join Date: Apr 2006       07-27-2008, 2:53 PM Reply
^^^^+1
Old     (buzz_grande)      Join Date: Mar 2004       07-27-2008, 3:40 PM Reply
I run 3 Pac-1's. One for the sub, one for the boat speakers, and one for the tower. Can't get much easier.
Old     (cccbuilders)      Join Date: Jun 2007       07-27-2008, 3:55 PM Reply
thx guys, must go shopping
Old     (wakeboardlasvegas)      Join Date: Mar 2007       07-27-2008, 4:05 PM Reply
I'll 3rd the Pac LC-1
Old     (audiopro74)      Join Date: Jun 2005       08-02-2008, 1:41 AM Reply
Deck with front, rear, and sub output. Just fade between front, and rear. Or if that is too much of a pain, due to location, or accessability, the LC-1's work great.
Old     (hatepain)      Join Date: Aug 2006       08-02-2008, 10:52 AM Reply
^^^^+3 for the front, rear and sub set up on the deck it's simple to just fade it front and rear. I also have a sub knob that came with the amp that I use which is nice when you get a little based out.
Old     (clubmyke)      Join Date: Aug 2004       08-02-2008, 1:31 PM Reply
just a fyi... some pac installs require long lengths of rca cables which can cause a lot of problems and additional parts (such as a line driver) due to output of the head unit (try to avoid rca cable lengths over 2 meters total)
some amps accept separate volume controls - much better due to running a volume cable than a signal cable.
Old     (number55)      Join Date: Jul 2007       08-02-2008, 1:56 PM Reply
Try a line level remote from radio shack. super cheap and easy to put in. gets the job done.
