Hello WakeWorld! I've been stalking this site since I picked up my 02 Supra SSV in October and I thought it was time to introduce myself and ask a couple questions too. I bought it winterized so wasn't even sure i ran it until this weekend. Overall everything is good except a couple small issues.
It looks like there is a leak coming from the Vdrive. If my research is correct I should just have to tighten a nut up to slow the leak down. I also might have to change some rope inside if it's worn out, does that sound right?
Even though the boat didn't come with any ballast bags, it did come with the pumps. We tried to test the pumps with very little success. The blue fitting is the fill line right? The front only pumped a little bit of water and the rear didn't pump anything. Also the drain tubes (if the blue is the fill tubes) are blocked off (see pic below). Could this keep water from coming out?
The biggest issue I have is my non working depth gauge. We go in some pretty shallow places and a gauge is a must. Right now it's showing a bunch of random numbers. Also, one of the 2 speedometers is really off. Any thoughts on how to square this away. And what's the point of two speedos anyways?
And now picture time
