06-02-2003, 9:57 AM
for those who made sub boxes in front of the driver, are you making formed fiberglass boxes or just close fitting wood boxes? while my sub amp is out of comission I may try to put the subs on the drivers side I have 02 wakesetter LXi subs are 2 infinity perfect 12 currently in cookie cutter 1 cu ft per sub sealed box in storage compartment I intend to keep i cu ft sealed.
06-02-2003, 10:53 AM
I used a wood box. I had mine in the storage compartment and moved it to the driverside and it is MUCH better. It is worth the time and effort!
06-02-2003, 6:34 PM
we are going to glass it, aside from any large flat spots. hopefully it will turn out to be saweet!
06-02-2003, 7:11 PM
Take a look at these... https://www.audioformz.com/storeindex.htm I'm installing mine next week at the driver's feet. I'm cutting an arch shaped hole in the stock footrest and sliding the enclosure in there. Of course, it is only 1-12", but I think it will look pretty cool!
06-02-2003, 7:36 PM
those are pretty cool I plan to replace the stock footrest with part of the box, and also somehow integrate the driver heater vent to make it trick. I will keep you all updated with what we decide to do.
06-03-2003, 8:45 AM
06-03-2003, 1:00 PM
I found a 10" box at futureshop that fits like a glove behind the kickpanel in my Toyota. wait a second. I dont think you folks have futureshop in the US. Oh well http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&dept=9&WLBS=fsweb9 &sku_id=0665000FS90532910&catid=&newdeptid=9
06-05-2003, 7:08 PM
We started glassing tonight. Kick panel is gone. didn't feel the need to move anything, as we will have plenty of box volume with the space we had to work with. we put a bunch of aluminum foil down, put a woven mat layer down and a couple of chopped mat layers down, for the shell. tomorrow we will remove the shell and start glassing the front of the box. we are going to run the heater vent through the box so it blows right on the drivers' feet and also going to make a pedestal to re-mount the depth finder (it is a fish finder that lets me see the contour of the bottom) this will allow me to regain use of the cupholder, as the depth finder was a tight fit. also removed the guage pod as i will likely never use it. This box is going to be TRICK, yet removable if anything ever needs service. I'll take pictures of the shell (in the boat) tomorrow evening before we mark it up for trimming. It is going to be so nice to have dry storage again.
06-06-2003, 5:16 PM
first pic
06-06-2003, 9:42 PM
tonight we marked where we want the box to go, took the shell out, added 4 more layers of chopped glass (mat) and made the speaker rings out of MDF. tomorrow we will trim the shell, start fabricating the top of the box, and probably decide upon placement of the speaker rings (they locate and flush mount the subs) we decided to nix the idea of a pedestal for the depth finder, as it would have to sit too far under the dash to allow good visual contact. it is tough to make (2) 12's fit under there without moving stuff around a lot, but I think we are definately going to accomplish this task. more photos to come tomorrow.
06-08-2003, 6:26 PM
more pics: shell trimmed: shell with top added (top is on the bottom in this pic) the top was flat so we used some masonite with an MDF rib to give it shape. inside of the box has been glassed with 3 layers in the corner and 2 layers on the masonite and rib. once the glass on the top had a while to cure, we checked to make sure we could get it in and out of the position in the boat. it went in like butta, so then we proceeded to locate the speaker rings. we double checked the depth requirement of the subs by using cardboard mockups, which we called 'top hats' the speaker rings were temporarily secured using hot glue and dowels, also some scrap wood was used to shim. Once the speaker rings were in place, the stretchy fabric was secured using contact spray, and contours were developed accordingly. the stretchy fabric was wetted with the fiberglass resin, and we left it to dry overnight. more fiberglass goes on the front and the top of the box tomorrow.
06-09-2003, 12:38 AM
looks good Tim, keep posting pics. Ive got a project in mind and was thinking 1/2" ply with glass inside and out and was wondering if it would be rigid enough? itll be for a ported 12 mounted up under the passenger side dash. Im trying to keep weight down since itll be hanging up under there and i know the speaker will be enough mass and dont want a 100 lb box/speaker combo. (Message edited by bob on June 09, 2003)
06-09-2003, 6:19 AM
Looks great Tim! Awsome project. Thanks for posting the info. I've got something in mind too, but I'm afraid I'll spend the time and money and it will sound like garbage. What do you do to figure air space on an irregular enclosure like that. I was thinking about just guessing and making it as large as possible. Then just add stuff to the inside of the enclosure until it sounded to the liking. Wrong approach?
06-09-2003, 6:57 AM
mark, that is exactly the approach we are taking. we know roughly how big the old wood box was, we know approx what 2 cu ft looks like. I understand the hesitation with the sound expectation. my buddy that is helping me did a box in his spare tire well in his trunk, and used a lot thinner fiberglass. I kept saying 'are you sure we don't need another layer' until it got pretty thick. bob, I think you could get away with it. just make sure to brace the inside of the box well
06-09-2003, 7:08 AM
Tim: Awesome Job Keep posting photo's www.svtsupercharged.com
06-09-2003, 5:48 PM
cool - maybe I'll go ahead and give it a shot sometime. Keep us updated on how it turns out.
06-10-2003, 5:37 AM
Mark one of the old trickes to find out how much air space you have in an irregular shaped box is to use water. Put a garbage bag into the shell that you first build and fill it with water. Then take a bucket or cooler or something and figure out the airspace of that. Empty the water into the container that you used and you can calculate the air space that you have and compair it to the recomendaed amount for the speakers. The nice thing about a fiberglass box is that it will not resonate like a wood box so it usually sounds better from the start.
06-10-2003, 7:23 AM
Thanks. I should have thought of that!
06-10-2003, 8:40 PM
Today's Achievements: Trimmed cloth from speaker holes now that it is dry: Fiberglassed front and top of box. Front recieved corner treatment + 3 layers, top recieved 2 layers. Top had 2 layers and 3 thick corner layers on the inside so no need to worry about the corners too much. Excess fibers were trimmed and speakers were test fit to make sure there were not problems. and there were no problems!!!! last step of the night was a good coating of bondo, to be sanded down tomorrow, then time for carpet to be applied. this picture is after only one layer of bondo, believe me we used a lot more than that. I am so excited that this thing is almost done. a ton of work so far, and I am ready to reap the benefits. Anyone have suggestions for grilles other than waffle type?
06-11-2003, 9:15 AM
How about these? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3029815686&category=18 803 Pretty loud, but they do make a statement. These things usually sell for a lot more, this this is a decent deal. The sub box looks great. I have a very similar set up in my car with the same mounting angles in a fiberglass box.
06-11-2003, 3:34 PM
Here's a pic of my latest install. My storage locker was water tight so I used mdf wood. and covered the front with matching vinal to repel water if they got sprinkled.
06-11-2003, 3:36 PM
sorry
06-11-2003, 3:37 PM
06-13-2003, 12:44 AM
Justin, looks like you were getting ALL the bass when it was turned up. How much power were you sending those 12's? at your feet?
06-13-2003, 6:08 AM
I'm pushing them with a 1000 watt amp, but the bass sounds good all over the boat. The subs are getting about 200-250 RMS. I like more bass than most people, but I still like to have a good mix with the highs and mids so it works out good. My tower speakers above me on the tower push all the highs and mids as well as the speakers in the boat and then the subs only push bass. (Message edited by dajuice on June 13, 2003)
06-13-2003, 10:00 AM
Quick question, early in this post someone said they had their sub in a wood enclosure inside their storage compartment. Was the storage compartment totally sealed? What I mean is did you have any holes out of the storage compartment to let the sound out? Or can you hear the sub through the compartment. I have a Tige' 22I with one sub under the dash, and want to put at least one more in the back left storage compartment and might put a third in the back right compartment. I was wondering if I need to make a hole in the compartment to hear the sub, I assumed yes, but maybe I don't. Thanks for your help. Jonathan
06-13-2003, 10:06 AM
Jonothan, about 75% of the reason I am buiding (or pretty much can say have built aside from the carpet) the box on the drivers side is the fact that the sound was attenuated a LOT in the storage compartment.
06-13-2003, 10:22 AM
Thanks, sounds like I definitely need to have a hole with a grill of some kind in the wall of the storage compartment in the back. I wish I could mount the sub there with a box behind it like I have under my feet on the kick panel. But it won't fit. I was going to have a custom box made to fit in the compartment with the sub angled towards an area where I can drill a hole in the side of the compartment "fiberglass area" to let the sound out. The hole will only be about 8 inches, but should work. Thanks again!
06-13-2003, 10:28 AM
by the way, have not carpeted the box yet, as I am waiting on the carpet, ordered from the malibu dealer this week. However, last night I installed the subs in the box, and placed it in the boat. It sounds great. the box is real 'dead' sounding, no resonance so that cleans up the sound a lot, and also no glovebox contents rattling. It hits hard. The driver (most of the time me) will have the best seat in the house for bass. haha
06-13-2003, 5:50 PM
here are some pics of the sub in the boat. on water testing proved that the box sounds incredible. ***Imagine it covered in grey carpet***
06-15-2003, 11:42 PM
Tim you got the wish i could here that monstrosity
