also, check your grounds. Sometimes, if there is multiple things on one ground, the pop can be genereated. I had something similar happen when I installed my pg amp. It turned out that I had grounded all of the relays for the ballast system onto the same ground as the amp. So, when ever i turned off the switch and the relay opened, a really annoying pop cam through. Fortunately, my amp has a switch for flat ground, regular, or a floating ground, which isolates the input from the chasis ground. It is either something similar to this or you just need to go through and check all of your wires and connections
