Watching my cards go one up on the tigers
I had to Eclipse they are slalom boats. So they always had a pull to the right. Jason is right any inboard or Vdrive that is pulling can be adjusted with a grinder.
does your speedo not work??
Jason is right about everything except the V the eclispe is flat as a board acros the back. Centurions usualy require more weight on the passenger side to clean up the wake side.
To make the wake bigger you will have to sac it down put weight on both sides of the engine and some up front.
Now there has to be somether BETTER but is escapes me
(Message edited by krbaugh on October 21, 2006)
