I had my engined pulled for my 330 HP 2000 X-star and had a smilar situation once the motor was back in the boat. If you look at the engine from the back seat, there is a bleed valve on the right side of the motor on top where the fuel line goes into the top of the engine. Unscrew the cap and push the pin in with a key or a screw driver. Have someone turn the boat over while you push in the pin, wait to see if any gas begins to leak out, if it does not, then probably is your pump. if you are getting fuel, then may be a connector under the back seat on top of your fuel tank or something else. You can contact me by email if you have any other questions.
