Do you have amps installed and are they connected through the same breaker? Here is the deal with that breaker: the alternator feeds the circuit on the load side, not the battery side (which I think is stupid, but thats the standard way its done). Because the alternator feeds the load side directly it will provide power to the circuit that does not pass through the breaker. So let's say you are cranking the stereo and your amps are pulling around 80 amps from the 12 volt line. When your engine is running the alternator will provide 40 amps or more of that demand, which means that the battery supplies the rest (40 or less). The circuit breaker only sees the current coming from the battery, and being a 60 amp breaker it is happy. Now you shut the engine off and the alternator output goes to zero. Now all 80 amps has to come from the battery, and the circuit breaker sees it all. If you have amps installed then I highly recommend that you wire them to a dedicated fuse/circuit breaker that connects directly to the battery istead of overloading the boats original electrical system. Rod
