04-10-2006, 5:00 AM
Hey All, I've seen a few posts regarding controling the volumne of the tower speakers independant from the "boat" system. Some folks have rigged a switch to merely turn the "boat" off or the tower off - does anyone make an L-Pad/potentiometer/volume control that could go in-line between the head unit and a dedicated amp (bridged) for just the tower? I was thinking something like one of the small controls that come with some amps that'll act like a bass boost. I've searched around and seen some folks use an equalizer for this purpose but that of course means another unit somewhere in/on the dash...I was thinking of just as simple knob... Whadaya think? Wes
04-10-2006, 5:24 AM
It is called a PAC LC-1, do a search there have been posts about it on here.
04-10-2006, 5:43 AM
Hey KJ, Thanks - dunno when I did the first search, nothing came up "under tower speaker volume" or whatever, in fact I searched "PAC LC-1" and nothing, so I googled the dang thing and voila!!! Looks like just the thing Thanks again Wes
04-10-2006, 8:05 AM
Awesome. I have been looking for something like that. I saw a post here the other day taling about it, but I thought it was just another EQ. This is what I am looking for too. Thanks KJ! Hey KJ, are you akdoc on tigeowners?
04-10-2006, 11:42 AM
Here's one I made. I used better pots than the LC-1 and modified the taper so it is more logarithmic. I also put in a port for my ipod shuffle. I run the head unit to a Planet Audio 6 channel preamp that ouputs 8vdc to this control, then to the amps.
04-10-2006, 7:11 PM
Ok, how do you use better pots? All a pot is, is an adjustable resistor. A resistor is a resistor. There is no need for tolerance, since the output is adjustable anyway. .... I am confused.
04-10-2006, 7:21 PM
A pot is not a resistor, it is a mechanical device. Why does an M class Mercedes cost more than a Kia Sportage? They are the same, right?
04-10-2006, 7:26 PM
Robb, Yes, I am akdoc on tigeowners. The pac lc-1 is a great option for simple control I did however buy an eq for our new boat. Glad I could help you all out.
04-10-2006, 7:51 PM
As per Wikipedia: The present popular usage of the term potentiometer (or 'pot' for short) describes an electronic component which has a user-adjustable resistance. Usually, this is a three-terminal resistor with a sliding contact in the center. If all three terminals are used, it acts as a variable voltage divider.
04-10-2006, 10:02 PM
Your point?
04-13-2006, 7:48 AM
Cyclone, I did not mean to offend you. I am sorry. I used the wrong words. I meant, "what do you mean by better pots?" Does that mean they have a greater range? ... Again I did not mean to insult you. I honestly didn't know what you meant. BTW, that thing looks cool. I like how you got the case to say Epic, and everything. It looks very professional. Robb (Message edited by boarder_x on April 13, 2006)
04-13-2006, 6:04 PM
No offense take, Robb! The pots don't have greater range, what they have is a modification to how loud they go based on how far you turn the pot. It's called taper. A half turn on a LC1 is not half the volume because they use linear taper pots. 1/2 turn is 1/2 the resistance but that doesn't take into account how your ear perceives changes in volume. So, I added a simple mod to a linear taper pot that makes it perform like a true analogue taper pot, works better when you are twisting the knobs when the rider falls, etc. 1/2 turn is 1/2 the volume. Glad you like the looks of the box, I used www.frontpanelexpress.com to make the faceplate. You can get anything you want from them, I used black anodized, engraved aluminum. I am working (not hard enough lately) on a speed based volume control so we won't need the knobs! (It's coming, I promise, Jim!!) Pete
04-14-2006, 1:02 PM
Sounds good Pete, the boxes are coming along nicely.
04-14-2006, 7:50 PM
This may be a dumb question but if I have a balance control and the tower speakers are together won't this do the same thing? My boat is new and I only had it out once and never messed with it I just assumed that is how it worked! Nice speaker boxes!
04-14-2006, 8:18 PM
yep but it's a pain to get to the balance control when you are driving the boat, pulling someone, drinking a (pepsi) messing with the ipod, etc. Knobs are easy to deal with, and you don't have to explain how they work to someone new to driving your boat.
