Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 22, 2006
Old    97on22s            05-01-2006, 6:07 PM Reply
What board is good for a begginer with bindings under 300?
and how does the board to persons wieght hieght work??
Old     (wakeriderixi)      Join Date: Jan 2004       05-01-2006, 6:25 PM Reply
here we go again.......... you can find 100 million posts on 'whats a good board'!
Old    97on22s            05-01-2006, 6:30 PM Reply
thanks!
Old     (chris_c)      Join Date: Jun 2005       05-01-2006, 6:30 PM Reply
i would check out some of last years model boards and bindings. i got an 04 vision blem for like 120 bucks last year and some other 100 dollar bindings. so if you can, look for a last year model board/bindings or a blem IMO.
and for the second question i probably couldnt answer that correctly.
hope that helped a little.
Old    97on22s            05-01-2006, 6:47 PM Reply
thanks..im looking at all these sites and the boards are like 125 130 144 not sure what number id need for my size..thats what i havent been able to figure out..or if it even matters that much
Old     (audiopro74)      Join Date: Jun 2005       05-01-2006, 6:52 PM Reply
matters alot. General rule of thumb is the bigger you are the longer the board. Except in cases like the Fish or Marius wich are wider than the average board.I'm 5'10" 230 lbs and I ride a 143
Old     (kristian)      Join Date: Nov 2002       05-01-2006, 6:55 PM Reply
Ryan, tell us your weight/height and we'll help you out.
Old    97on22s            05-01-2006, 6:56 PM Reply
im 6ft 160 lbs
and the other board will be for 5ft 4" 115 lb person
Thanks guys.
Old     (kristian)      Join Date: Nov 2002       05-01-2006, 7:06 PM Reply
well for you I'd recomend the 138-142 area
and the other around a 130.
Old     (wakeriderixi)      Join Date: Jan 2004       05-01-2006, 8:06 PM Reply
K.Coltman has got the sizes correct.... As for boards... check out Liquid Force Trips and Hyperlite Motives. Check your local shop, or wherever you want to buy from to see what they have.. post the names and you will get a ton of advice and reviews on whatever it is!
