Old     (ironcross25)      Join Date: Jul 2006       06-23-2008, 7:24 AM Reply
Ok I am in the process of fixing some things and my tach has not been working. My question is where does it connect on the engine?? What should i check to diagnose? Thanks
Old     (lovin_the_wake)      Join Date: Jul 2007       06-23-2008, 8:19 AM Reply
Mine doesn't work either it goes up to 1000 and that's it
Old     (da_mose)      Join Date: Apr 2008       06-23-2008, 11:19 AM Reply
Here is a PDF scan of the electrical system Wiring Diagram from my 89 Sunsport Owners Manual titled Supra the 19'Series.
application/pdfUpload
Supra.pdf (91.8 k)
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-23-2008, 1:15 PM Reply
usually off the distributor. not exactly sure how, since mine has two wires. pos and neg.
Old     (ironcross25)      Join Date: Jul 2006       06-24-2008, 5:27 AM Reply
On my 406 sbc in my nova it hooks in to the distributor which is the standard GM with an ignition that replaces the stock right on the cap. The boat had the coil seperate for the ignition so I just trying to fing the right wires. My boat has been such a PITA so far this year. If its not one thing its another thing.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-24-2008, 7:12 AM Reply
have you checked the guage?
Old     (ironcross25)      Join Date: Jul 2006       06-24-2008, 7:39 AM Reply
Ive checked all the wires and they seem to look fine. no corrosion and are nice and tight.
Old     (rallyart)      Join Date: Nov 2006       06-24-2008, 7:56 AM Reply
Tachometers normally get their signal from the negative side of the coil. Usually boats use a grey wire for the tach signal. The tach needs to have a ground and some also need power and a lighting power source. Should be four wires max. and could be two.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-24-2008, 8:51 AM Reply
That makes sense. 4 wires on the coil.
