Old     (dcooper)      Join Date: Mar 2005       08-14-2006, 11:34 AM Reply
So, we have been having engine trouble, sometimes the engine gets bogged down when towing someone and slow to respond. Not consistenlty, the engines just seems under a bigger load sometimes than others. Nothing has changed, like weight or number of people.
The boat is 2001 Supra w/5.7 330hp indmar w/ 159hrs. Never done anything except oil changes and impeller change.
So is this a maintenance issue spark plugs, timing etc? Or do I have bigger or other problems?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       08-14-2006, 12:20 PM Reply
carbed?
Old     (dcooper)      Join Date: Mar 2005       08-14-2006, 12:48 PM Reply
No injected "MPI"
Old     (rich_g)      Join Date: May 2003       08-14-2006, 1:14 PM Reply
replace the water/fuel separator; could be clogged and its an easy thing to eliminate as a possibility
Old     (trace)      Join Date: Feb 2002       08-14-2006, 1:15 PM Reply
If you haven't lately, change your fuel filter and check / clean the pickup screen.
Old     (dcooper)      Join Date: Mar 2005       08-14-2006, 1:21 PM Reply
What is the pickup screen?
Is there a fuel filter and a water/fuel separator?
Old     (trace)      Join Date: Feb 2002       08-14-2006, 1:35 PM Reply
Not all boats have water separators, which usually look like big spin-on oil filters. The pickup screen is in the gas tank, on the end of the pickup tube.
Old     (acurtis_ttu)      Join Date: May 2004       08-14-2006, 3:03 PM Reply
Could have also just gotten some bad gas.
Old     (dcooper)      Join Date: Mar 2005       08-14-2006, 3:10 PM Reply
So, at this point it should not need to have a "tune-up" so to speak? Just check the filter and maybe run the gas out...
Old     (trace)      Join Date: Feb 2002       08-15-2006, 6:33 AM Reply
Your description sounds like fuel starvation or maybe bad gas to me. A "tune-up" on an EFI motor doesn't encompass much, these days - change the fluids, fuel filter, and maybe the spark plugs.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       08-15-2006, 7:58 AM Reply
sounds like fuel filter: trace the line from the tank. look for a fuel/water separator too
Old     (fogey)      Join Date: Mar 2002       08-15-2006, 9:29 AM Reply
The fuel/water separator is probably at the front of the engine (nearest the transom) on the port side. As someone said, it looks like a large spin-on oil filter. It's not too hard to access, but you may need an oil filter wrench to remove it.
I think it also serves as the fuel filter, as I have not found any other fuel filter on my Supra.
Old     (dcooper)      Join Date: Mar 2005       08-15-2006, 10:02 AM Reply
Thanks, I'll check the fuel/water separator.
