Hi, I have a 2001 Mastercraft X-10. When cold & still slightly warm, up until about 20 minutes of running, when I put it in gear (engagement is normal) and start adding throttle, there is a slight "bump" like it wasn't completely in gear. Or like there is some kind of slack in the drive line. After it is completely warmed up, it stops doing this. If you go from pulling someone and just slow down to idle, then throttle back up again, it doesn't happen again (even when cold) but if you take it back to full neutral and start over, it keeps happening Until Completely Warm. It is very slight and I seem to be the only person that notices it (probably because Im the only one that will have to pay for it) but it has been doing this for about 2 years now (since I purchased the boat). I did not notice it when I purchased it. Any idea what this could be? Or how to fix it? There are no other symptoms along with this "bump" or slight clunk. My fear is that if someone else is pulling me, that they may put it in gear and give it full throttle, and what ever is bumping breaks. Thank you}
