Wheel hubs will get some heat into them just by rolling, yours sound OK. If you are using the brakes a lot that will increase the amount of heat, again normal unless you have a brake jam then you will feel it quite a bit hotter than the other side. One thing about bearings and seals, you see a lot of people drive down to the ramp and reverse their trailer straight in, BIG MISTAKE, hot hubs dunked into water will create a gap in the seals and allow water to penetrate. A good practice is to do your pre-launch checks and give the hubs time to cool a little.
