Old    brycejay            04-29-2009, 7:26 PM Reply
I just picked up a 99 SAN and the engine compartment cover (v-drive) wont open. Is there some kind of trick to opening these? There arent any latches or anything that I can see and I feel like if I lift up any harder I'm going to break something.
Old     (wakesk8er2)      Join Date: Mar 2002       04-29-2009, 7:29 PM Reply
They are automatic. There's a three way toggle switch to the rear of your throttle. Push up and it should go right on up.
Old    brycejay            04-29-2009, 7:49 PM Reply
Got it. I'm an idiot. Thanks for the quick response
Old     (wakesk8er2)      Join Date: Mar 2002       04-29-2009, 7:55 PM Reply
Glad you figured it out and didn't do any prying on the deck lid. Remember too, unless you have the second battery in the bow, the battery is back there as well. If it ever goes dead, you have to take out the back seat to get to the battery.
Old    brycejay            04-29-2009, 9:49 PM Reply
Yeah, I saw the battery back there. Thanks a lot. Do you have an older SAN?
Old     (wakesk8er2)      Join Date: Mar 2002       04-30-2009, 7:24 AM Reply
No. My cousin has had the same boat since it was new, so I've spent quite a bit of time out on it and messing with it.
Old     (nautiquesonly)      Join Date: Sep 2007       04-30-2009, 6:50 PM Reply
bryce I had a 2000 san very similar to yours if you have questions I may be able to help
Old     (trace)      Join Date: Feb 2002       05-01-2009, 7:22 AM Reply
You can't pull the lid hinge pins if the battery dies? You can on the older Malibu VLX's. I always hated the power lift. I changed mine to gas springs and a latch a few years ago, and it is MUCH better.
I gotta ask - you bought a boat without looking at the motor?
Old     (insuranceman)      Join Date: Jun 2005       05-01-2009, 7:26 AM Reply
damm trace, my thoughts also!
Old     (wakesk8er2)      Join Date: Mar 2002       05-01-2009, 6:44 PM Reply
you can pull the pin, but you still gotta take the back seat out. If I had one I'd be figuring out how to rig up a three piece deck lid.
Old    brycejay            05-02-2009, 1:22 AM Reply
Another question... which impeller should i buy? I went to whitelake.com an wasn't sure if i should buy the johnson or the sherwood. thanks
Old     (superairdawg)      Join Date: May 2003       05-02-2009, 11:31 AM Reply
The raw water pump should be a Sherwood, so I'd go with it.
