YES... YOU CAN BRIDGE A HEAD UNIT BUILT IN AMP!!! Go find yourself a head unit that has the bold print on the face plate... 4x50 watts. Then bridge it... 2 x 100 watts Then take your two speakers... positive to positive and negative to negative... twist together and connect!!!! You should be pumping 2 x 200 watts... or even better... add another two pairs and drop your impedance to 1/2 ohm... You should be able to get close to 500 watts out of that bad boy... Might out power your sub and tower speakers... but it will kick a$$!!! After you do it... post on here and let us know how it all worked out... Best of luck!
