The Firewire folks announce the product here:
http://www.firewiresurfboards.com/forum/comments.php?DiscussionID=242&page=1#Item_0 Deepcove has the concept. I don't know that it will work behind the boat well, we don't have real significant top and bottom turns. From that forum, I cut 'n pasted:
Here's how it works.
Forward fin cant (how the fin tilts in relation to the bottom of the board) is normally set between 6 and 9 degrees, increasing speed through turns and drawing tighter arcs than more upright fins.
The DEVIANT fin applies that same principle to the rear thruster fin. The DEVIANT automatically adjusts 7 degrees of cant in either direction (14 degrees total range of movement) and noticeably increases speed and responsiveness by reducing rear fin drag, loosening the tail, and shortening the turn radius of a thruster fin set up: your board will feel more maneuverable.
We've been riding the prototypes for a couple of months now, from San Diego beach breaks to Hawaii and Tavarua and felt the benefits of the canted rear fin immediately.
The DEVIANT will come in FCS and Futures compatible versions and there will be demo fins at all Firewire Retailers. You don't have to take out word for it, just try it. I think the logic behind how it works is pretty easy to grasp. I'm sure someone will comment about the possibility of increased drag from the wider base. However, in all of our testing across a wide variety of conditions and surfing abilities, if there was any extra drag created by the base, it was more than offset by allowing the rear fin to mimic the front fin cant through turns. All we felt was increased responsiveness and speed through turns.
