Old     (ship_of_fools)      Join Date: Sep 2007       02-17-2011, 8:34 PM Reply
I am trying to set up a semi ballast system in my boat. I have found most of the stuff I need but this last connection has eluded me!
I will have (2) 3/4" drain lines that I would like to connect to the bilge drain. I have 1" outlet and a 1" bilge drain now.
I would like to tie the (2) 3/4" drains lines together with a "Y" fitting like the one below before teeing into the bilge drain. But, I would like to find a 1" Y connector instead of a 3/4".
http://www.shopping.com/T-H-Marine-3...-H-Marine/info
I would also like to use a 1" "sweep" T connector (like a sanitary T PVC plumbing elbow) to give better flow direction where it will pump into the bilge line. But again, I can't find a 1" fitting.
http://www.google.com/products/catal...d=0CFMQ8gIwAA#
Any ideas of places to look or other things to try?
Old     (wake_upppp)      Join Date: Nov 2003       02-17-2011, 8:53 PM Reply
Try here. www.marineeast.com and www.Mcmaster-Carr.com
Old     (ship_of_fools)      Join Date: Sep 2007       02-17-2011, 9:12 PM Reply
Thanks, but I still didn't find anything in either one.
Old     (spencerwm)      Join Date: Feb 2009       02-18-2011, 8:52 AM Reply
I know you are probably trying to avoid adding another thru-hull to the boat but it would be a lot cheaper.
I would use a 1" barbed tee fitting with a 1" check valve on the bilge side that only allows water up and out to eliminate the need for a sweep.
I would then use the 3/4" barbed wye fitting to connect the two drain lines and run them up to a 1" to 3/4" reducer fitting and connect that to the 1" tee fitting.
There are going to be a lot of solutions to this project. Have a good day and have fun with the system.
Old     (spencerwm)      Join Date: Feb 2009       02-18-2011, 9:03 AM Reply
Sorry this is not the best diagram but it is what I was thinking.
Old     (ship_of_fools)      Join Date: Sep 2007       02-18-2011, 10:17 AM Reply
Yea, what you are describing is probably what I will have to do. In fact, I was looking at those exact fittings from the same supplier.
I was just hoping I could find a 1" Y so that the (2) 3/4 lines would come out as a 1" line instead of combining (2) 3/4" and netting one 3/4" output.
Just seemed to make sense since I had to convert everything to a 1" line any way, thought it would be better to do it at the Y (or right before it) instead of after.
Thanks.
