Old     (calaman)      Join Date: Apr 2007       08-07-2011, 10:07 AM Reply
Hi all,
Having an issue with the ballast not draining. Triple ballast, front and right drains no issue, left no go. Blown 5amp fuse. Replace with good 5amp fuse and the left drains for about 5 seconds then blows. Tried to reset main ballast fuses, nothing changes. Any advise would be great. Thanks
Old     (07launch22ssv)      Join Date: Feb 2007       08-07-2011, 10:41 AM Reply
what year? if it has the seperate pumps for empty replace that pump it is blown and shorting thats why it keeps popping the fuse.
Old     (calaman)      Join Date: Apr 2007       08-07-2011, 11:44 AM Reply
07
2 of 3 ballast empty no prb. 1 fill and 1 empty pump setup with the sprinkler valve ghetto setup is what I have.
Old     (bzubke1)      Join Date: Feb 2010       08-07-2011, 1:07 PM Reply
This happend with one of the pumps on my moomba which has the same ballast system as your supra. It would keep blowing fuses every couple times out until it finally stopped working all together. Rplaced it and everything is good.
Old     (Bumpass1)      Join Date: Oct 2010       08-07-2011, 3:02 PM Reply
Bad pump motors increasing amp draw causing fuses to pop. Replace pumps.
Old     (calaman)      Join Date: Apr 2007       08-07-2011, 7:47 PM Reply
Bummer, was hoping for something else, thanks guys for the response.
Old     (jonyb)      Join Date: Nov 2008       08-07-2011, 7:56 PM Reply
i've been through about 8 of those pumps on my 07....
Old     (calaman)      Join Date: Apr 2007       08-08-2011, 7:18 AM Reply
John 8, that sucks. Something causing a short or crappy pumps?
Old     (07launch22ssv)      Join Date: Feb 2007       08-08-2011, 7:23 AM Reply
when those pumps blow it is usually caused by 2 things, being run dry for an extended period or something obstructing the flow.
