Old     (Pacificnwflyguy)      Join Date: Apr 2010       06-30-2017, 9:24 AM Reply
I have a 2007 Supra 22 SSV and the center bag keeps filling uncommanded without the pump being on, any ideas!!?? Perhaps just replace the main ballast pump?? Thank you for any insight
Old     (Stazi)      Join Date: Sep 2011       06-30-2017, 11:16 AM Reply
You have sprinkler valves and the one for the center bag is probably shot and stuck open. You can replace it with a similar valve from Lowes or Home Depot.
Old     (racer808)      Join Date: Jan 2013       06-30-2017, 12:00 PM Reply
If the pump impeller is bad it will allow water siphon in & out. If you close the valve & it doesn't do it then your valve is fine. You may also want to consider putting an anti siphon loop in the hose to prevent this. My old boat with aerator pumps did this & anti siphon look took care of it.
Old     (jonblarc7)      Join Date: Jul 2006       06-30-2017, 1:21 PM Reply
been there done that it is a sprinkler valves.
Replace it with one of these from Lowes hardware for 10 bucks
https://www.lowes.com/pd/Orbit-3-4-i...-Valve/1091027
Cut the wires and use some butt connector to wire in the new valve.
Old     (jonblarc7)      Join Date: Jul 2006       06-30-2017, 1:23 PM Reply
You can close the valve like Jack is talking about by turning the black tab on the top of the valve. It's the little tab of the left side of the pic in the link I posted.
Old     (ryan_shima1)      Join Date: Sep 2002 Location: Layton, Utah       07-01-2017, 8:46 PM Reply
If the black tab is in the wrong position, it will gravity fill on it's own. When it's in the correct position, it will engage when using the switch on the dash. But if the entire valve is indeed bad, that will need to be replaced like others have mentioned above.
Old     (jzelt)      Join Date: Oct 2011       07-28-2017, 12:36 PM Reply
I plumbed in a ball valve in the locker that I just flip when I want to fill.
