What fittings do you use to connect hose to the old water bed style Fly High Fat Sacs? It would seem to me that they would be prone to leaking. Also, the two sacs that I bought only have fill/drain holes next to eachother on the top of the sacs...what about venting and draining?
I you need water bed fittings, I have 5 of them. They are fairly new. If you are plumbing the sacks into a ballast system, use a little bit of silicone on the threads. pm me if you are interested in fittings. $1.00 each + shipping
You can use standard 1 inch barb fittings. I just switched from the waterbed ones in my two sacks in the back lockers. Just worked them in there without glue or anyhing and there is no leaking.
