Old                08-24-2005, 7:24 AM Reply
anyone have any suggestions on HS or TS ole 5's. Shawn Watson makes them look so sick, there definately the most stylish looking trick out. they almost look just like a roll to revert or scarecrow just laid out with an overhead handle pass.
Old     (thane_dogg)      Join Date: Jun 2002       08-26-2005, 11:28 AM Reply
there was an instructional for the hs olé 5 in either the last issue of alliance or the issue before that.
Old                02-07-2006, 7:41 AM Reply
I just learned those this past summer and they are actually fairly easy. I think the trick is to be able to do really solid off-axis 5's. Once you get those down all you really have to do is when you go to pass the handle instead of passing it just take it over your head.
Old     (doogles)      Join Date: May 2004       04-21-2006, 3:19 PM Reply
For a Toeside Ole 540's.....there's a few things to think about.
1. Grab First....if you're going to make this trick look right (aka Like Watson does them) you need to grab with your front hand...you can do a number of grabs, but I prefer mute. Remember to bring the board up right off the wake and get the grab before thinking about the spin or the flip.
2. After getting the grab, jerk the handle in hard. I usually think about pulling it right into my armpit to get some slack in the line to do the trick
3. After jerking the handle in, pull it up and over your head...kind of similar to the handle pull on a whirly bird.
4. Really try and keep your board as on-axis as possible...it'll go off a little, but the closer to on-axis the better it will look.
Some similar tricks are a mute scarecrow and a grabbed o/a 540....the big difference on this one for me was figuring out how to pull the handle in to get some slack on the line. Good luck!
