Old     (Wiatowski)      Join Date: Aug 2011       09-19-2011, 12:54 PM Reply
Hey, just bought a used pair of 2010 Ronix One Black bindings. Tried them the other night and my set only lasted 10 mins before I had to take them off. My feet were so sore I could barely walk. They've never been molded so should I mold them before I try them again?
I found them hard to get into even with soap.I wear a size 10 shoe so I bought a size 10 binding.... should I go for a larger size? or will molding them say in hot water stretch them a bit?
Help my feet.... please!
Old     (jsmilez321)      Join Date: Sep 2011       09-19-2011, 2:07 PM Reply
man i wear a size 10.5 -11 and i have the ronix ones 2010 size 11 i love them, but i molded mine with the ol hair dryer and sock method before i ever strapped them on. Those things are sooooo comfy i wouldnt buy another type.
Old     (fifty)      Join Date: Aug 2011       09-19-2011, 2:14 PM Reply
same here man... I got the 2012 ones and the first time I tried the on I thought no way!!! too smalll
I heat molded them and rode 3 sets now they are bang on! real nice bindings
Old     (Wiatowski)      Join Date: Aug 2011       09-19-2011, 2:48 PM Reply
which method is better, hair dryer or really hot water in the tub? I was thinking the tub cause then I could use soap if I had to to get them on.
What do you think?
And what's the deal with the sock?
Old     (jsmilez321)      Join Date: Sep 2011       09-19-2011, 6:13 PM Reply
Well man when I was putting the hair dryer inside the boot the thing was getting way to hot to put my bare foot in there so I just put on a sock that went mid way up my calf... Then tightened them pretty tight and stood still for like ten minutes... Or u could just go to a ski shop most of them have a professional heater to mold them.... Either way keep us posted
Old     (Wiatowski)      Join Date: Aug 2011       09-19-2011, 6:23 PM Reply
I'll be sure to try it. Will let you know how it works out.
Old    readyaimfire            09-20-2011, 3:39 AM Reply
I wouldn't use soap to put them on. Definitely heat mold them.
Old     (Bumpass1)      Join Date: Oct 2010       09-20-2011, 4:36 AM Reply
I have a pair of 2010 Ones. I love them. I could wear them all day.
Old     (smitty1258)      Join Date: Jun 2009       09-20-2011, 5:45 AM Reply
I also have 2010 ones and love them.
Old     (Wiatowski)      Join Date: Aug 2011       09-20-2011, 7:09 AM Reply
Ya but to make my feet hurt to the point of not being able to walk.... well sucks.
I have wide feet and high arches, and I'm hoping that molding them will stretch them a little. Cause when I really like the board control I had with them... could really feel the board.
Wondered if I should go a size up though. What do you guys think? Heat mold or go 1 size bigger?
I won't have time to try it till tomorrow so I'm trying to decide what to do.
Old    LR3w8kbrdr            09-20-2011, 7:45 AM Reply
I wear a 10-10.5 shoe and rode the Ronix Ones size 11 this past weekend. My old Ronix kais were 10. But i have skinny feet. All my other bindings are 10-11 and still snug. Id say go up a size
Old     (MattieK27)      Join Date: Mar 2010       09-20-2011, 8:05 AM Reply
Shoe size 11-11.5 here, got 2011 Ronix Ones in a size 11. They were tight at first, but after a few sets they fit perfectly. They never hurt my feet though, I do have narrow feet though. If it hurt so much you couldnt walk, you might need to go a size up.
Old     (fifty)      Join Date: Aug 2011       09-20-2011, 4:21 PM Reply
go true size... dont use a hair dryer go to a snow board shop and use their heater (hair dryer will over heat them.) use a thick sock to give a bit more room while molding them. then ride a few sets. I really did not think mine would loosen up but they did man after bout 3 sets.
Old     (Wiatowski)      Join Date: Aug 2011       09-21-2011, 8:44 AM Reply
Hey all got them molded today..... What a difference. Wore them around my place for like 45 mins, have happy feet. Can't wait to take them to the water.
Thanks all
BTW used the bath tub method worked like a charm.
Old     (joeshmoe)      Join Date: Jan 2003       09-21-2011, 2:27 PM Reply
how did you mold them?
Old     (Wiatowski)      Join Date: Aug 2011       09-21-2011, 2:42 PM Reply
Put them in a rubbermaid tub and filled it with hot water from the tub (our water gets so hot it steams) left them in there for almost 10 mins.
took them out, drained the water out of them, and put my socked feet into them and cinched them up tight. Stood on one place for about 10 mins, then walked around the house with them for another 30 mins or so.
took them off, took off the socks and put them back on and they fit perfect.
Old     (fifty)      Join Date: Aug 2011       09-21-2011, 7:08 PM Reply
good to hear man!!
Old     (501s)      Join Date: Feb 2010       09-21-2011, 11:18 PM Reply
In my opinion, nothing comes close. They are hands down the best boots I have owned. I did heat mold them at a snowboard shop.
Old     (Wiatowski)      Join Date: Aug 2011       09-22-2011, 2:26 PM Reply
Closest spot around me with a heat molder is 40 miles, and they charge $30..... home method proved effective. Will hit the water with them tomorrow and report.
Old     (joeshmoe)      Join Date: Jan 2003       09-22-2011, 3:01 PM Reply
sounds good! I will try it, water temperature is about 130 degrees?
Old     (Wiatowski)      Join Date: Aug 2011       09-22-2011, 8:26 PM Reply
Read on one of the forms that 120-140. I couldn't tell you what the temp was..... other than hot. Will tell you that you have to hold them down in the water.
Old     (jrbishop4)      Join Date: Mar 2007       09-23-2011, 2:56 PM Reply
try not to pull the bottom laces to much when you put them on. My feet hurt really bad when I first rode with my new pair of ones and the ronix rep told me it was because I was pulling the laces to tight. After that i have never had a problem and love my ones.
Old     (Wiatowski)      Join Date: Aug 2011       09-24-2011, 7:13 PM Reply
Just an update. Went for a long set tonight, about 10 mins in they hurt a little nothing like before, kept riding cause .... well I'm a man. By the end of the set they were comfy. I rode for around 2 hrs tonight had 2 - 15 min breaks in the water... Had no one else that want to ride. Water is at 65 and my buddies are chickening out already. Makes me sad to think I might only have a couple of more weeks to go at it.
Anyways all crying aside, I would say that molding them was a definite must for me and my fat feet. Thanks for all the input.
Old     (Chunk12)      Join Date: Aug 2011       09-29-2011, 11:09 AM Reply
Hey, i have the reliks size 11 and i think they may be a tad big. Do you think molding them would help at all?
Old     (Kane)      Join Date: Mar 2010       09-29-2011, 12:42 PM Reply
My Ronix Ones are humming.
I've only had them a month, only ride fresh water, leave them to dry in my shed.
Anyone have this issue or have any suggestions to stop it?
My old Cells never had this problem.
Old     (Wiatowski)      Join Date: Aug 2011       09-29-2011, 1:26 PM Reply
I wouldn't think so cause molding mine made them bigger. Ever try wearing thick socks in them, or those Lycra ones?
Old     (Wiatowski)      Join Date: Aug 2011       09-29-2011, 1:27 PM Reply
What's humming?
Old     (Kane)      Join Date: Mar 2010       09-29-2011, 1:49 PM Reply
they smell, real bad.
Old     (Wiatowski)      Join Date: Aug 2011       09-29-2011, 2:24 PM Reply
Someone suggested to me before that I put diluted dish liquid in mine before I ride, they always smell nice. If they get a bit funky I donit before and after I ride, then rinse them.
Old     (Chunk12)      Join Date: Aug 2011       09-29-2011, 2:35 PM Reply
i have thought of socks. I am going to try that. What are the Lycra socks?
Old     (Wiatowski)      Join Date: Aug 2011       09-29-2011, 7:17 PM Reply
check ebay.... there like scuba socks.
Old     (ridin_sidways)      Join Date: May 2006       09-30-2011, 4:06 PM Reply
Some of the CWB boots have Superfeet.
