Old    boardergirl128            08-22-2002, 9:10 PM Reply
i cant seem to get air off the wake. When i try i hit and only get an inch or so. i think its my fins or my aproach
Old    boardergirl128            08-22-2002, 9:14 PM Reply
also everyone says to keep the rope at your side and i do that and it wont work
(Message edited by boardergirl128 on August 22, 2002)
Old    ngthing            08-23-2002, 2:18 AM Reply
you need to learn how to edge. and don't blame it on your equipment, it's you ;)
Old    boardergirl128            08-23-2002, 11:47 AM Reply
I do edge it but I think not hard enough?
and I think its my fins because there surf dogs, and there meant for just riding inside the wake. I think Ineed carving fins
Old     (solo)      Join Date: Oct 2001       08-23-2002, 12:05 PM Reply
Try standing tall at the wake. Body position is essential. Don't absorb the wake with your knees. Hold your edge all the way through the wake. When in the air, spot your landing then look for the opposing shoreline.
Old     (dakid)      Join Date: Feb 2001       08-23-2002, 1:19 PM Reply
Katie,
Don't get frustrated. It takes time.
There are a few keys to getting good air...progressive cut, standing tall, body and handle position. Refer to this:
http://www.wakeworld.com/Tricklist/TrickTip009.asp
Read it. Apply it next time you ride.
Old    boardergirl128            08-23-2002, 9:50 PM Reply
when your in mid air should you push the handel down??
Old     (davidbouvier)      Join Date: Aug 2002       08-24-2002, 4:01 AM Reply
you can push the handle down if your unbalanced or out of control. if you cut and pop correctly you should land the same way you left the wake. sounds like your breaking at the waste and flattening out before the wake. you can work on your form by only cutting out 5 feet. go slow and work on proper form. when that gets comfortable go out a little furter. It's not just your approach and pop to work on, make sure you coast after cutting out before you cut back in.nKeep constant tension on the rope. enjoy
Old    boardergirl128            08-25-2002, 1:13 PM Reply
thx a lot
Old    wakeboard_luva            08-27-2002, 4:55 PM Reply
fins are fins surf dog or not u can get air off any fin(or at least any fin i can think of) so(quoting jonathan nq) don't blame You'r equipment!!
Old                04-21-2003, 4:28 PM Reply
kewel
Old                05-02-2003, 12:58 AM Reply
I know you have heard progressive edge everywhere you research on how to jump the wake. what that means is when you cut into the wake, start gradually and build up speed as you approach. I know when i first started i would go way out, cut real hard, but i would reach my top speed about half way too the wake and then loose all my tension. Build up speed to the wake, you should be accelerating all the way through, and once you are at the very top, push off the top. Think of that and what dave said, you should be able to get it, just stay in control. And about your fins, it's not that, if you are edging right you don't even need fins to jump. (landings, not as easy.)
Old                08-08-2003, 6:02 PM Reply
This might not be ur case but i noticed the same thing the first week i started. I noticed that i was going to slow. At 16 mphs you cant come into the wake with any speed.
