if you go to the hyperlite website than to gear than advantage these boards and boots come up some of them ive never heard of can someone explain to me whats up with this Advantage Line CalibreThe Calibre is a shape built for the intermediate to advanced rider. It has all the speed and pop you could ever want in a board. Features: 3-Stage rocker, Thin profile, Tip to tail step down rail, Concave footbed, Reduced swing weight, Tip to tail base channel, 7" molded in fins, Dual tip and tail flow channels Fins: 2 - 1.1" aluminum 135 139 Base SolutionThe Solution is a shape built for the intermediate to advanced rider. It has all the speed and pop you could ever want in a board. Features: 3-Stage rocker , Thin profile , Tip to tail step down rail, Concave footbed, Reduced swing weight, Tip to tail base channel, 7" molded in fins, Dual tip and tail flow channels Fins: 2 - 1.1" aluminum 135 139 Base LogicThe Logic series is perfect for beginner to intermediate the riders. This four fin shape makes for a responsive ride. Features: Abrupt continuous rocker, Variable edge design, Elevated heel and toe platform, Reduced swing weight, Four molded in base stabilizers, 6 degree angled fins Fins: 4 - 1.3" plastic 134 139 Base AllureThe Allure is the perfect fit for any female rider. Features: Abrupt continuous rocker, Variable edge design, Elevated heel and toe platform, Reduced swing weight, Four molded in base stabilizers, 6 degree angled fins Fins: 4 - 1.3" poly 134 Base FactorThe Factor is the perfect board for your first time behind the boat. Features: Continuous rocker, Soft and forgiving 6º bevel edge , 3" molded in fins, Tip to tail base channels Fins: 2 - 2.1" poly 134 140 Base StateThe State series is an asymmetrical shape great for all abilities. Features: Subtle 3 stage rocker, Asymmetrical heel and toe edge, Tip and tail step down edge, 7" molded in fins, Heel side flow channels Fins: 2 - 1.3" poly 125 Base 130 Base VoyagerThe Voyager is the perfect board for all the little rippers out there. Features: Continuous rocker, Soft and forgiving 6º bevel edge , 3” molded in fins, Tip to tail base channels Fins: 2 - 2.1" poly Voyager Base HelosFeatures: Fixed adjustable EVA toe, Articulating cuff, Dual density footbed, Quick cinch lace zone, Molded EVA heel and toe, Molded heel bumps Sizes: STD, XL FoundationFeatures: Adjustable floating EVA toe, Articulating cuff, Quick cinch lace zone, Molded EVA heel and toe, Molded heel bumps Sizes: STD, XL OrbitFeatures: Adjustable floating toe, Articulating cuff, Quick cinch bungee lace zone, Molded EVA heel Sizes: STD, XL White NoiseFeatures: Supportive molded EVA toe, Articulating cuff, Quick cinch lace zone, Dual density footbed, Molded EVA heel, Independent option 2 strap, Molded EVA heel and toe, Molded heel bumps Sizes: XS-S, M, L Black NoiseFeatures: Supportive molded EVA toe, Articulating cuff, Quick cinch lace zone, Dual density footbed, Molded EVA heel, Independent option 2 strap, Molded EVA heel and toe, Molded heel bumps Sizes: XS-S, M, L
