Old     (moman)      Join Date: Feb 2006       04-26-2010, 8:31 PM Reply
Looking for some help. I have six interior speakers. 2 up front, 4 in the main seating area. The two on the right side of the main seating area have a high pitch signal noise coming through them. Nothing in the left side, front speakers, tower speakers or sub. Is this a grounding issue, wire, connections? Anyone had this problem?
Old     (justintime)      Join Date: Mar 2009       04-26-2010, 8:36 PM Reply
Usually this is the RCA cables
swap them and see if it follows
Old     (moman)      Join Date: Feb 2006       04-28-2010, 5:19 PM Reply
I will have to give this a look the next time I am on the water. I don't get the condition when the engine is off.
I would conclude that I am getting some sort of engine feed back, but why on only one side and just the rears cabin?
Old     (gti2lo)      Join Date: Nov 2005       04-28-2010, 6:59 PM Reply
I think it's the RCA's giving feedback... I am no expert.. let one of the audio guys touch base on this.
Old     (espritv8)      Join Date: Dec 2009       04-28-2010, 9:19 PM Reply
This is called noise, usually it's because RCA's are too close to power wiring. It alsco could be a bad ground.
If you research ''sound system noise'' you should get the info needed.
