Weight will often case the wake to do other things, along with increasing the size (soft vs hard wake, wash out, lip size/shape). Most people running big weight also board faster and use longer lines. Is it an I/O, not sure what an azure is. If it is, try trimming the outdrive. Fool around with it once your boat is weighted and see if you can get the wake to clean up.
