Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (victory07rdr)      Join Date: Aug 2008       02-28-2009, 12:40 PM Reply
Any tips on re-doing my trailer bunks for the first time? What wood, carpet, glue? I've heard SS staples but how many staples do you use? All up and down the board, or just on the ends where carpet folds over? Thanks
Old     (dhcomp)      Join Date: Jun 2003       02-28-2009, 1:10 PM Reply
You may want to reconsider doing this yourself if you have so many questions.
You can buy marine bunk carpet at marine stores. Use stainless staples if you want it to last. I never used any glue. Staple it along the side, where you fold it, everywhere besides where the boat will sit. It will stay on longer this way.
Really, with common sense....its pretty hard to screw up this project.
Good luck!
Old     (rvh3)      Join Date: Jul 2003       02-28-2009, 1:25 PM Reply
You can get the carpet at Home Depot.
Old     (stephan)      Join Date: Nov 2002       02-28-2009, 2:11 PM Reply
It is a pretty easy project. Use treated wood and staple like crazy. Instead of completely wrapping the board we've left the bottom uncovered to allow for drainage. Personally glue on the top will help prevent the carpet from ever slipping
Old     (1boarder_kevin)      Join Date: Mar 2007       03-01-2009, 1:04 PM Reply
cut a strip of carpet just as wide as the top of the board and then put the final layer on top of this. As stated above, leave most of the bottom uncovered so it drain/dry.
Other than just pulling it tight and stapling (SS staples) it on the sides and bottom it is straightforward. Check your boards to make sure they are in good shape. The big issue normally is what to do with your boat. I went to the boat ramp and tied the boat up and did it right at the ramp. Tools are just a screwdriver/needlenose pliers to pull old staples, utility knife with a lot of blades ready and a staple gun.
Old     (bftskir)      Join Date: Jan 2004       03-01-2009, 2:02 PM Reply
I would not waste my time trying to reuse the old wood pulling staples etc, use new pressure treated wood and only one layer of carpet, use the stuff they sell for bunks, use stainless steel staples(if you have an air powered stapler it works better than a spring type) you can then do all the work at home/shop then just go down to the ramp to launch and swap them out in the parking lot, then all is brand spankin new(also might want to get new galv lag bolts too.)
Old     (oshelton)      Join Date: Oct 2001       03-01-2009, 3:06 PM Reply
Only reuse your current boards if they are pressure treated. Forget pulling the staples. Either cut the carpet off or apply new carpet over the old carpet. If your current boards are not pressure treated, toss them and buy new boards. Buy marine grade carpet to minimize mold, mildew and rotting. Use stainless steel stapes. Galvanized staples will not stand up against chemicals now used to pressure treat lumber.
We offer 20 oz marine grade carpet already slit into 14"W x 100'L rolls. Contact Jerry at info@boatmatetrailers.com.
Old     (kko13)      Join Date: Jul 2006       03-01-2009, 3:09 PM Reply
All the above is good advice. just check to see what is holding the boards on now some use carriage bolts not lag bolts. If you go back with carriage bolts they have to be put in before you put the carpet on.
