Was just wondering.....Seems like when I take the boat out if I manually thrown on the bildge pump I get between 1-2 gallons and then when I pull the rear plug and put it on an angle I get another 1-2. And this is on a day with no sack's or swimming. Just crusing. Does this seem like a lot or possible leak?
Everything is completely dry in mine at the end of the day. The area around the plug is not even wet. If I am in and out of water a lot and wakeboarding then I get some water in but only minimal. It sounds like a small leak to me.
Do you have a dripless packing gland? If not you may be out of adjustment and you are dripping faster than normal. I would check that first. How old is your boat? My old 210 ballast lines would leak some water in sometimes if I left the hull valve open even when not using the ballast.
Jay i just had this very issue on my '07 Mobius LSV the last two times out since purchase. It seemed like a lot of water was in the bilge and as the '07 Moombas have dripless packing glands i was wondering were it was coming from. While checking the oil the other day i noticed water was dripping at the rate of almost two drips a second from a connection at a hose that came off of the port side exhaust manifold. The hose had a connection that looked exactly like a male/female garden hose connected together and it goes towards the bow. I'm guessing it's for the heater but i've yet to check. Anyway it was real loose so i tightened it up and hardly any water the rest of the day in the bilge, what was there was from the cooler i believe.
Thanks for the info. I dont have a heater though I think Im going to pull out all the bags dry out the inside of the boat and take her to the lake and look everywhere. I dont think I got to the point where the bildge turned on but it seems like a lot to me.....
Razzman - the garden hose connection comuing off of the manifold is the quick drain for the manifolds that allow you to drain the manifolds for winterizing. It's very possible that they didn't get tightened back up good enough.
Thanks Richard for the clarification, makes sense, this is the first Vdrive i've owned, all the others were older DD's so i'm unfamiliar with some stuff. It goes back this week for some minor fixes so i'm going to have them go over everything.
my 07 mobius has the same problem....bilge triggers a couple times a run....there's no structural damage cuz it sits still in the water and remains dry...its leaking somewhere while running
if it is equipped with a hot/cold shower assembly check (all) connections to make sure they are tight on the block, as they are a very common source of (excessive) bilge water (if not tight) when boat is running..
So I found the leak today. Its the Master ballast pump right above the hole in the hull. I couldn't tell if it was the fitting or the pump itself due to the angle. I turned off the main copper hard valve before the pump and it stopped. Guess it will be fixed at my 20 hour service
Suprised no one asked if you have tightened up the prop shaft seal yet? When mine wasnt tight, I got about 3 or 4 gal in the bilge at the end of the day. I tightened it up and am suprised if I see a gallon.
Well I finally got out for 6 hours on Saturday. I guess my shop loves a loose nut on the shaft... Freakin bunches of water in there after that day. Oh well... that's why they put a bilge pump in
