Be sure after replacing the impeller, you check the old impeller fins. Make sure none broke off and possibly got through the filter to plug up some of the water jackets. Also be sure to check the Thermostat and make sure it is opening properly. You may even want to take it off and visually inspect it to be sure there is no corrosion.
