09-20-2005, 7:07 PM
in a 2002 Supra (320hp indamar motor) what "Type" of engine would this be? (chev, ford, etc...) and what are the avalibility of parts for these motors?
09-20-2005, 7:22 PM
Indmar uses GM blocks, and parts are very easy to find. See your local marina for conversion part numbers.
09-20-2005, 8:51 PM
make sure they are marine parts and not car parts...
09-20-2005, 11:39 PM
5.7L / 350 cu.in. Chevy longblock marinized by Indmar. Very solid, similar to what is used in Malibu, Mastercraft, and many others. Parts are very common some need to be marine specific others don't.
09-21-2005, 9:02 AM
What about a starter? Why would it need to be marine?
09-21-2005, 9:07 AM
because starters and mounted on the bottom of the engine, and if there is water in the bilge it can splash up on to them.
09-21-2005, 9:53 AM
Starter, alternator, ignition, are all marine specific because they need to be spark free so things don't go boom if gas vapors get trapped under the motorbox. Of course the raw water pump, exhaust manifolds, transmission, and a few other systems are marine specific as well. I have been involved with the marinizing of a few automotive motors, send me a message if you have a specific question, I will do my best to answer it.
09-21-2005, 9:55 AM
Include cam, valve springs, and cam followers (usually roller type) are different/stouter than most automotive applications.
09-21-2005, 10:49 AM
Mikeski, So is using the blower before starting the boat just a precaution if they are not marine parts? I recently installed a new starter from NAPA and I'm not sure if it's marine.
09-21-2005, 11:07 AM
No, the blower is essential. Marine parts simply limit the speed and probability of the explosion. It does not elimnate it. If you have a NAPA non-marine starter, chance are you are running dangerous and your insurance policy may not cover the incident. Check your policy. Most require the boat to be maintained in NMMA or USCG approved condition. Using a non-USCG starter would void the policy. The difference is screens and plates that reduce the amount of air that can escape quickly from the casing. NAPA does carry Marine starters, so check out the numbers. Good Luck.
09-21-2005, 11:11 AM
Has anyone ever seen an engine compartment ignite? Just wondering....I haven't ever heard of any stories related to this....
09-21-2005, 11:36 AM
Yep...seen a boat burn to the waterline too.
09-21-2005, 11:49 AM
We just had one on our waters burn to the waterline. here's a pic before she sank.
09-21-2005, 11:50 AM
09-22-2005, 8:07 AM
Entire families have been blown up on inboard ski or wakeboarding boats. The danger is not imaginary.
09-22-2005, 10:01 AM
These things happen but keep in mind that we are all probably taking a much greater risk just driving down the highway getting to the water... I like to use my nose to give a sniff under the motor cover at the beginning of each outing. If I smell fuel vapors I don't turn anything on until every hatch gets opened and aired out. It's the cheapest insurance.
