Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 29, 2006
Old     (wakesetter101)      Join Date: Oct 2005       08-07-2006, 2:41 PM Reply
Are you suppose to have bass blockers in your tower speakers? I am just curious to see who is wanting bass come through there tower speakers.
I have a set of kicker dual voice coil 6.5 tower speakers and were thinking about installing bass blockers any thoughts?
Old     (mikeski)      Join Date: Aug 2003       08-07-2006, 4:51 PM Reply
Bass blockers aka capacitors are not a bad idea on tower speakers. A better idea is to enable your amplifier's high pass crossover tuned to about 150hz. The speaker's are not going to produce much down there anyway so you might as well save that power (heat) and use it where it's more audible.
Old     (malibu_monkey)      Join Date: Apr 2006       08-07-2006, 5:11 PM Reply
Just CRANK EM TILL THEY BLOW!!!
Old     (audiopro74)      Join Date: Jun 2005       08-07-2006, 5:44 PM Reply
The only reason you should need them is if the amp does not have a crossover.
Old     (clubmyke)      Join Date: Aug 2004       08-07-2006, 5:51 PM Reply
electronic crossover would be much better (more efficent and you can experiment)..most amps have this built in..
for 6.5's 150hz is a good place to crossover..
Old     (wakesetter101)      Join Date: Oct 2005       08-07-2006, 8:39 PM Reply
I do have my amp set that way. I guess i was just seeing what others have done. Thanks
Old     (puckinshat)      Join Date: Sep 2003       08-07-2006, 10:42 PM Reply
Otherwise if you have a kenwood excelon deck, the crossover is built into that. If no dice on either, get some bass blockers.
